How to fit the 600 into the 3tj
hunter
Re: How to fit the 600 into the 3tj
Post by hunter »
dobbslc,i'v found my bracket,but mine is steel with good threads,
Im now just waiting for some suspension measurement off tim so that i can finnish my hybrid :whistle:
sparkles
Bike owned: 1990 fzr6 3he with a 4jh engin
Post by sparkles »
Im running 3he carbs on a 4jh engine but air box dont quiet aline up so will have to mod the box to fit
Thanks to this site and Fzrtim i have solved a few problems with my 3he bike fitted with a 4jh engine which ive spent quiet a few months looking for the answers to my questions.
Does any one have a 3he wiring diagram that shows (or able to tell me) whay colour wire goes from cdi box to fuel pump relay ?
Post by Evilchicken0 »
3HE is standard FZR600 so it should be findable on the web. Type in fzr600 manual download and google it maybe or they'll probably be one on a disc through e-bay
sparkles
Post by sparkles »
Evilchicken0 wrote:3HE is standard FZR600 so it should be findable on the web. Type in fzr600 manual download and google it maybe or they'll probably be one on a disc through e-bay
Thanks but done all that with no joy even joined 2 fzr forums with no luck of finding information out.
I cant get disc from ebay as lost count how many times ive tried to setup paypal also not working so have to do everything on the cheap as chips policy
plodder
Post by plodder »
sparkles wrote:Does any one have a 3he wiring diagram that shows (or able to tell me) whay colour wire goes from cdi box to fuel pump relay ?
I think that's in the Haynes book for FZR600/750/1000. I'll have a look when I get a chance.
sparkles
Post by sparkles »
Thanks but have looked at wiring diagram in haynes manual for my bikes lots but it only shows which wires go to main relay but not what each wire is for
have come across other wiring diagrams that show what each wire is for in the main relay but dont think there for my bike
blueboy
Post by blueboy »
Hi Tim do you serll these mounting plates? As I have just bought a rrsp with a cat engine, And it has been badly fitted, hope you can help steve.
bendy3
Bike owned: FZR400RRSP FZR400 HYBRID RRSP
Post by bendy3 »
Hi, I'll make you some plates when I fit mine. ;)
Ive just bought a fzr600r engine and the carbs have a throttle position sensor on them. The cdi is a 4jh as the engine is. Is this going to cause a problem when I try and adapt my 3tj loom, or can I leave it disconnected? :?
The throttle sensor is from a Thundercat I think it's ok to use them with connectingas your using the 600R Foxeye CDI
I't's easier to use a Foxeye loom though
bendy3
Post by bendy3 »
I have the loom with it, it could be that it has thundercat carbs on maybe? Or did the later foxeye model have a tps? I dont have the clocks and was wanting to use the 3tj clocks, this is why I was wanting to use the 3tj loom :?
