BHP for a standard NC29 ?
vr46
- Bike owned: All sorts
Hi All,
I've been told that the standard BHP at the rear wheel for NC29 is 50BHP, is that right
Skint Novice F400
scratchin
Re: BHP for a standard NC29 ?
should be more like 56-58
PARUS
here is more info on the NC29'svr46 wrote:Hi All,
http://vsource.org/VFR-RVF_files/Bcbr400rr-mi.htm" onclick="window.open(this.href);return false;
You can check for the specifications of your bike at the link given below... mine is a 91 L model (59bhp , 44KW@12500rpm), the L and N model produced 59bhp, but found the R model was changed to a lower capacity 53bhp, 39.5KW@13000rpm. I don't know the reason.
lazcbr29
- Bike owned: kawasaki ar 50, Honda CBR 125
ive got an R model,
i spoke to graeme apparently they only carb rubber restrictors.
couldn't say why?
Laz
couldn't say why?
Laz
vr46
PARUS wrote:here is more info on the NC29'svr46 wrote:Hi All,
Ahhh
How do I fix the problem and get more like 59 BHP?
Do I fit carb rubbers from a different model?
Thanks all :) !!
Skint Novice F400
vr46
lazcbr29
when i spoke to graeme he said they were in the carb rubber itself.
should just be glued in, apparently they're just like the 33bhp restrictors?
best thing to do would be is ring him.
laz
laz
- Davez29
- Bike owned: NC29 forever
I have the R model and just have had my carbs apart, I could not see any restrictions in mine but did notice a groove (ledge?) that is presumably for restrictors as I tried some metal ones I had and they fit fine. BTW dont buy the carb rubbers from China on ebay, they dont fit and have a thicker mounting as I found out to my cost.
- alexhumber
After reading this thread I have dug out the dyno result for my NC29.
68.3bhp @ 12844rpm and 4.3Kgm (stupid metric torque units) @ 10465rpm.
Sounds impressive, but this was done in January 2002 using an obnoxiously loud exhuast
and I'm not so sure if it is that power stat is applicable now, especially with my more village-friendly
end can!
vr46
Thanks all, I'm gonna fit carb rubbers from an earlier model and see how it goes :)
Skint Novice F400
