r6 shock conversion on a genesis
martynfzr
has anyone got the instruction for this conversion as i have lost the ones i had
cheers martyn
cheers martyn
Re: r6 shock conversion on a genesis
Take the old one out and compare the lenghts. Round off the R6 bottom mount similar to the oringinal.
Fit it all up .... on the 3en's you need to have a "jack up kit" which are new dog bones - you can get them on e-bay.
Set the preload on the softest setting.
martynfzr
i thought there was a spacer that you had to have made up
cheers martyn
cheers martyn
Taggyd
only in the 3tj, the 3en1's have shorter shocks, nearer the length of the r6 on so dog bones will sort it!
oh you may have to add washers in the top mount to pack out each side.
