WTB NC35 HT leads and caps
- Reactions:
- Bike owned: 1994 RVF400R, 1995 TZR 125 x 2
Need to replace an HT lead and cap for the NC35.
So far have not found anything on the OEM part number.
Any idea where I can source an aftermarket unit or which manufacturer of leads still currently produce to the NC35 spec?
- Reactions:
Re: WTB NC35 HT leads and caps
Howdo Mal
Welcome.
You'll be needing one of these chaps to deal with -
https://www.rickoliver.co.uk/stocklist.pdf - Rick Oliver
Graeme France Racing
07522 166832 - Andy
gfracingtw@live.co.uk
Welcome.
07522 166832 - Andy
- Reactions:
- Reactions:
Found a set of leads and caps off of a NC24. Are these compatible or should I stick to looking for units off an NC30 (as the NC35 units are nigh on impossible to find locally and cannot find the apparent compatible SD05FM caps from NGK at any of our local parts stores - NGK themselves are less than useless here too).
- Reactions:
- Reactions:
RVFmal wrote: ↑Tue Nov 07, 2023 10:53 amFound a set of leads and caps off of a NC24. Are these compatible or should I stick to looking for units off an NC30 (as the NC35 units are nigh on impossible to find locally and cannot find the apparent compatible SD05FM caps from NGK at any of our local parts stores - NGK themselves are less than useless here too).
Bigger plugs on an NC24 so not sure they would work?
Is it a spare you need, or new? Mighthave one in my container that I might be visiting this weekend - if I find one, I'll let you know
- Reactions:
I had a chat to Rick Oliver and he advised me that the plug caps could be repaired, which is a win (even sent me a how-to). So got some 7mm HT lead and will perform a repair this evening and give it a whirl.
As an side, I did check whether the NC24 caps would fit and as you rightly stated, they do not
- Reactions:
Awesome - Rick is a good man indeed.RVFmal wrote: ↑Mon Nov 13, 2023 2:41 pmI had a chat to Rick Oliver and he advised me that the plug caps could be repaired, which is a win (even sent me a how-to). So got some 7mm HT lead and will perform a repair this evening and give it a whirl.
- Reactions:
