Draining coolant, no manual
- Reactions:
Hi everyone,
I recently shipped my NC23 (K) across Europe after it had been sat indoors for a few years, and naturally will be replacing all the fluids.
Unfortunately I forgot to send the manual, and whilst most of this won't be a problem, I'm not sure where is best to drain the coolant from.
Any advice and/or pictures would be appreciated :D
Thanks.
Thanks.
- Reactions:
Re: Draining coolant, no manual
There should be a 8mm bolt in middle of water pump housing..undo that and it will drain the system..or just pop off the lower radiator hose...
- Reactions:
