had a little slip on the CBR 400 going left outside my house. Roads are slippy!
- Reactions:
- Bike owned: cbr 400 zxr 400 gsx 1300r
Hi all,
I had a little slip on the CBR going left outside my home and down the road for football at 9pm.
Broke the brake lever, throttle cable housing a little messed up, brake lever scratched, frame scratched and clutch cover a little scratched as well
here are some pics and I am completely fine.
https://postimg.cc/TKXc8hK9
https://postimg.cc/z3zBQNDg
https://postimg.cc/zb9xV7fm
- Reactions:
Re: had a little slip on the CBR 400 going left outside my house. Roads are slippy!
Such a shame glad you are ok mate :)
- Reactions:
- Bike owned: NC35 NC29 Bonneville CBR600F4i
Yeah, you need to be extra careful at this time of year. I expect you've already started looking for parts. NC29 bits seem rarer than the V4's. I've seen brake pedal assemblies around and a replacement brake lever is easy of course. Clutch covers are a bit tricky. You'll probably be able to improve on the scratched frame but it's not easy to make that sort of damage disappear completely. Looks like you've got a bar end missing and the right indicator is obviously adrift. No damage to bodywork?
- Reactions:
Yes I am ok thanks. I have another stock handle bar with the bar end. I also need to get a new throttle tube as it is broke. I got second hand good brake and clutch lever. I have got two other clutch covers and one is painted by a shop. Just need to swap it. I did not have any fairings on and for this reason of possibly dropping it. I am going to put my R & G crash bungs on it, like I should have done before the crash.Foxy400 wrote: ↑Tue Dec 03, 2019 5:53 pmYeah, you need to be extra careful at this time of year. I expect you've already started looking for parts. NC29 bits seem rarer than the V4's. I've seen brake pedal assemblies around and a replacement brake lever is easy of course. Clutch covers are a bit tricky. You'll probably be able to improve on the scratched frame but it's not easy to make that sort of damage disappear completely. Looks like you've got a bar end missing and the right indicator is obviously adrift. No damage to bodywork?
I got a brake pedal of a good friend, you can probably guess who that is
I have a spare screen as well in the house.
- Reactions:
That friend wouldn't be Davez29 by any chance?
- Reactions:
- Bike owned: NC29 CBR600F
Re: Just bought a Kawasaki ZXR 400 1999
Post by Bowches » Sun Dec 08, 2019 3:33pm
haha im not breaking my NC29. I'm doing it up, painting the wheels, callipers, new rear shock and front springs (forks) and carb clean and tune.
Will you be putting the fairings back on along with using crash bungs?
And im not after buying them i am only asking if you would be returning the bike back to its original form
- Reactions:
When the bike has the fairings on, I prefer without the crash bungs but ill have to drill a hole really I guess and put the crash bungs because when the bike drops on the floor it is such a headache fixing this thing.cbr400rrn wrote: ↑Sun Dec 08, 2019 8:59 pmRe: Just bought a Kawasaki ZXR 400 1999
I cant be spending my money on fixing shit endlessly lol
- Reactions:
What about Chinese fairings? I know they aren't the best fit straight out of the box but can be made to look ok with a bit of modifying, that way you can keep your oe ones and use the Chinese ones with the crash brings.
I've had mine a few years now (12) and still like the look of it im sure you are the same or you would have got shut after the tumble its just taken.
Remember 'pics or it never happened'
- Reactions:
Don't drill holes in your fairing panels! These things are like hen's teeth. If yours are half-decent try to look after them. The Chinese fairing idea may be a good option for you if you keep dropping the bike..or stabilisersBowches wrote: ↑Wed Dec 11, 2019 12:08 amWhen the bike has the fairings on, I prefer without the crash bungs but ill have to drill a hole really I guess and put the crash bungs because when the bike drops on the floor it is such a headache fixing this thing.cbr400rrn wrote: ↑Sun Dec 08, 2019 8:59 pmRe: Just bought a Kawasaki ZXR 400 1999
- Reactions:
I just sent my rear wheel to get painted along with my front brake callipers. Painting the brake callipers silver, same colour as the forks I told him and then rear wheel gloss black. The previous wheel was painted gloss black as well. The bearing F***** the wheel, some bits of the bearing was in the rear wheel and did not want to come out.
I bought a second wheel from Andrew Simon for 40 pounds, so was ok.
