tyga carbon silencer position
brido
Reactions:
Post by brido » Wed Jul 11, 2018 1:39 am
Hi all I’m having a problem with my tyga carbon silencer position when I fit it onto my bike, the bike has a full tyga system but when I fit the longer carbon silencer it pulls up against the indicator, I think I might be right in saying that this is the wrong position, any ideas in what might be wrong with what I’m doing, photos below to show you what I mean,
Image23C39CCD-19BC-4BF2-9397-12842D57E60A by rossi55, on Flickr
Image18F2F497-3A8C-4C1B-92A3-49766DBA018E by rossi55, on Flickr
ImageC9541002-552D-4D34-94F4-2B8BA2C7CA7C by rossi55, on Flickr
Image20CE00A5-6896-49C2-9CB8-5C14641512A8 by rossi55, on Flickr
SPOONDIDDLY
Reactions:
Re: tyga carbon silencer position
Post by SPOONDIDDLY » Wed Jul 11, 2018 10:04 am
Have you tried adjusting the position of the muffler and routing of the exhaust?
There is a fair amount of play in the system, so you can probably get it to work
Foxy400
Reactions:
Bike owned: NC35 NC29 Bonneville XS400
Post by Foxy400 » Thu Jul 12, 2018 9:17 am
I had a similar problem when I fitted the exact same Tyga can to my NC35, except I have the original indicators and the can touched the outside edge, rather than the underside as yours does.
I tried adjusting the system but there wasn't enough flexibility to clear the indicator. Eventually I added an extra nut and 3 washers to the bolt which holds the strap to the hanger. I put them on the bolt BETWEEN the strap and the hanger, which had the effect of pushing the can outwards several mm. and therefore clearing the indicator..just. I think I may have used a longer bolt to accommodate the additional fittings.
You could try something similar but it looks like you would need to add more nuts and washers than I did to move the can out enough. You don't notice the extras on mine but you may do if you add significantly more. I also thought about removing the hanger and trying to bend it slightly (in a vice). I even bought a spare one to try it but in the end didn't need to. That might be an option for you.
brido
Reactions:
Post by brido » Thu Jul 12, 2018 8:38 pm
I have tried both the ways you have mentioned but every time I go to tighten up the clamp it pulls the silencer up where it shouldn’t be.
I have looked at that but mine is too far in for that, mine needs lowered, so I might have to make some kind of bracket to lower the hanger.
Foxy400
Reactions:
Post by Foxy400 » Fri Jul 13, 2018 10:35 am
Yup, that's an option. I considered it but got away without the hassle of making one. If I was to make a bracket to lower the hangar by a few mm. I would design it so that it fitted to the 2 bolts on the frame rail, then bolt the hangar to it, rather than make a bracket that fits between the hangar and the strap, which is likely to look a bit weird. The bracket would be out of sight behind the seat panel and would probably be more secure. Just in case you haven't already thought of that!
brido
Reactions:
Post by brido » Fri Jul 13, 2018 8:09 pm
Was thinking the same thing,
Was wondering if this is a common problem with the tyga silencers.
Foxy400
Reactions:
Post by Foxy400 » Sat Jul 14, 2018 9:58 am
Don't know if other people on here have had the same issue but I'd be interested to know how you solve the problem.
NGneer
Reactions:
Post by NGneer » Mon Jul 16, 2018 12:35 pm
Do you need the Tyga exhaust hanger to go with the Tyga exhaust system?
Might be worth asking if someone out there with a Tyga hanger could measure the distance between the hole centres to see if theirs is slightly longer than the OEM one thus holding the silencer down a bit away from the indicator. Just a thought
Second thought: You could also try drilling a second hole in the Hanger and pivoting it down slightly, like so...
My hanger already had a second set of holes drilled and I did this to move the strap forward a bit (off the Ethos label) but thinking about the geometry of it...it must also have moved it down slightly. Might be enough to give you the clearance you need. :peace:
brido
Reactions:
Post by brido » Tue Jul 17, 2018 8:39 pm
Thanks NGneer I’ll enquire with the tyga importer and see what he says, but it doesn’t say anything on their website about using a tyga exhaust hanger that’s what made me think it’s compatible with the oem hanger.
I have a spare hanger so I’ll definitely give that a go and see what happens.
brido
Reactions:
Post by brido » Thu Jul 19, 2018 11:11 pm
Finally got round to removing the seat unit and have noticed that the sub frame has a curve in it, should it be their or should it be straight?
Return to “V4 - Workshop”
