FZR400 RR at dynojet
				enduro250
- Bike owned: FZR 400 RRSP, FZR 400 RR (2)
HI all,
I was at the dynoyet today with the first 3tJ.
Standard motor without modifications.
K&N single airfilter
Carburetor changes according to Yamaha Race Kit.
Race exhaust similar to the RaceKit without EXUP, similar to BDK Race Engineering.
Result: 65 PS @ 13.200
37Nm @ 10.800
Rear wheel power !!!
Exceeds my expectations
Those are 70+ PS at the engine.
any comments and recommendations are welcome.
dynojet printout will follow in the evening
37Nm @ 10.800
Re: FZR400 RR at dynojet
Sounds healthy :)
				enduro250
sorry, have tried to login at tinypic or photobucket, was not working.
so cannot show the dynojet printouts
yes, you are right, it was planed to achieve a very stable and healthy version.
It is intended as the basis for the next engines to show which changes bring which success.
next step will be my SP engine and to the above mentioned changes, BDK airbox and ignition adjustment (BDK) will be added
results will be posted here again.
That will be interesting. I'd expect the SP (standard) to be similar to the RR but pick up and make it's revs a bit quicker.
				Maelstrom
- Bike owned: MC22, 3TJ1
Here is the dyno sheet.
Carb seal kits in viton & other parts
https://litetek.co
						https://litetek.co
All top end, you can see why ditching the exup isn't good for a road bike
				enduro250
THX Blair, for hosting!
yes it a race bike only.
the previous run was with 125 main jet, showing quiet the same (no data sheet available).
we increased to 130 main jet, but almost no changes, we expected a richer mixture, on top end.
so I set the needle one ring up to increase the mixture, but no time left for an additional dyno run.
I am using standard RR carbs.
so I have tried to increase the diameter of the main air jet, like on my SP carbs ( -->120) with a taper reamer.
and now I assume I have opened them too much and results in a too lean mixture.
any experiences, further tips?
THX
THX
				enduro250
sorry data sheet is in german.
the red line is the power (wheelpower)
the blackline is the air fuel ratio
Next week I will have the first test of my SP.
So I will update this thread as soon I have results.
BR
BR
				enduro250
here is the sheet of the first dyno run of my SP
THX again Blair, for hosting
stock engine,
mainair jet 120
main jet 128
needle 5CZ (stock SP)
needle position 3 (from top)
no airbox
no airfilter
no generator
It was just for synchronization and basic setting for HC and CO values.
Thought, it will be easier to do this settings, before I build in the airbox.
So it is just to know where we are starting.
But was a bit surprised about the bunked out line (power) between 12k to 15k, especially, the lambda value is not so bad in the range of 14k to 15k. I know such lines if the engine is running much to rich.
the blue line is wheel power
the black one is air / fule ratio
stock engine,
mainair jet 120
main jet 128
no airbox
no airfilter
no generator
Which lines are which ?
