Low voltage reading and dim lights ?
Re: Low voltage reading and dim lights ?
Just measure across the battery terminals
				ArronA
I think the electrics have been tampered with in the passed or something has been added as up from by the speedo there is a black box with a cable ties around it that has about 6 to 8 blue wires coming off it, i remember the guy that i got the bike off saying something about the headlight isn't standard so it could be something to do with that i don't know but the headlight wasn't dim when i first got the bike and now it is, voltage across the battery is about 11.7v and it doesn't increase to 12 odd volts until 5k rpm
The box sounds like a m-max to remove the japanese top speed restriction. The head ligHT might have been swapped for anot her Yamaha model there's a few that will fit.
				ArronA
Yep downloaded that manual and my carb settings are to a "T" of those in the manual mind you it doesn't give you a float height setting in MM neither a needle clip position, the only other things i can think of is them being out of balance as you said however i can't get 2 of the screws out off the inlets so i can wind in the pipe fittings for my CarbTune Pro, also my exup cables have frayed and birds nested and jammed up so I've taken the valve out and made a plate and bolted it over the hole, also I'm going to need to look into having the valves clearances checked and re shimmed if necessary as that's not something I'm confident with doing unfortunatelyEvilchicken0 wrote:The box sounds like a m-max to remove the japanese top speed restriction. The head ligHT might have been swapped for anot her Yamaha model there's a few that will fit.
 I'll probably end up giving up with the bloody thing if something needs doing to it that i can't do lol
  I'll probably end up giving up with the bloody thing if something needs doing to it that i can't do lol-
Ahhh I see
So first go to Venhill and get and exup cable recore kit and reinstall the exup. The bike will be running lean low down in the Rev range and they're hard to retune with any success.
Do this and it should run a lot better
				dobbslc
Something like 60 volts AC between the phases. I would test it while it's still connected though.
				ArronA
I don't no if I'm doing something wrong but i was only getting - 00.4 coming up on the multi meter surly that can't be right as the bike wouldn't start with that kind of voltagedobbslc wrote:Something like 60 volts AC between the phases. I would test it while it's still connected though.
				dobbslc
Are you measuring between the yellow wires and not to ground?
Ie yellow to yellow you should get about 60 volts. Make sure your meter is set to AC!
Test three times between the different wires, if you mark them A, B, C then measure between A&B then A&C then B&C.
Might be worth checking the meter is working ok too.
				ArronA
My meter does AC & DC but there is no switch that switches between the 2, yeah i did go from yellow wire to yellow wire and not yellow to ground :) i am beginning to think my meter might be at fault as I've had it years!dobbslc wrote:Are you measuring between the yellow wires and not to ground?
				dobbslc
I can't ever remember seeing a meter that auto ranges between AD & DC! Might be worth a trip to Maplins / Halfords for a new one.
I'm thinking if it was stuck on dc it wouldn't read anything!
