2 quick questions
maciekmaciek19
2 quick questions
Friends,
I'm too lazy to search the forum so want to ask.
1. I have a replacement chain but it's already joined (riveted) - can this be fitted without un-riveting or swingarm removal?
2. My bike is gettinh quite hot the gauge goes right under the red line. There are clouds of steam coming out from the wate 'bottle' under the seat. Is this because the system is overfilled? I have replaced the coolant recently and might have put in too much.
I'll appreciate your comments.
- Psychosomatic88
Re: 2 quick questions
1) No
2) unlikely
2) unlikely
Going on the internet is like owning a gun... Just point, click, then shit your pants waiting for the Police to turn up.
Psychosomatic88 wrote:1) No
2) unlikely
LOL- short and sweet
1> don't bother, just get a new chain..
2> make sure the air is bled from the system. Should not get clouds of steam from the coolant bottle at all
- Psychosomatic88
Well I couldnt be bothered to type a proper answer
Its worth thrying to bleed at the water pump and all the other drain plugs to start with
Psychosomatic88 wrote:Well I couldnt be bothered to type a proper answer![]()
Well...it is worth searching too..but some lazy buggers cannot be bothered
- Psychosomatic88
Thats what baffles me you know.
It takes more effort to type the question than a search string. Oh well life's mysteries
You can't technically over-fill the coolant. The rad should be filled to the top and the expansion bottle to the max line.maciekmaciek19 wrote:Friends,
Steam means its boiling and if it's getting that hot you may damage the bike.
You say you replaced the coolant, did you bleed air from the system afterwards?
maciekmaciek19
HI,
I think I need to bleed it properly. I hope Haynes explains how to.
I thought it would push the air out through the open rad with engine running...
You need to burp it a bit really. give the hoses a squeeze and get the bubbles out of it.
maciekmaciek19
YEah, will try tonight. I get to work on boiling bike every morning for past week. Need to sort this out before something bad happens to the V4...
