Bad start
Re: Bad start
Post by Evilchicken0 »
First thing with the plugs is to check the engine is clean, if it's dirty you can knock crap into the open holes ... and your hands get dirty.
I take off the front mud guard and undo the radiator so it's just on the hoses and you move it around a bit. Of course you could take the rad off and replace the coolant depending on it's colour in the rad and expansion bottle. If you replace the plugs you'll be fine with copper core, I fit the twin electrode CR9ek http://www.sparkplugs.co.uk/ngk-spark-plug-cr9ek
It sounds more like the carbs though, clean and balance them that should improve things.
Dcrosby13
Bike owned: RSV-R,RD350,MV F4,FZR,ST2,GSXR
Re: Bad start
Post by Dcrosby13 »
Thanks for the advice guys I will get stuck in at the weekend.
Dcrosby13
Re: Bad start
Post by Dcrosby13 »
Ok so this turned out to be something simple after all, does anyone have a spare good ignition coil for cylinders 3 and 4?
willandrip
Re: Bad start
Post by willandrip »
Drunkn Munky wrote:Mis behaving 3TJ's :o My advice run a mile lol
Mind it helps if you turn the fuel tap back on. :grin:
willandrip
Re: Bad start
Dcrosby13 wrote: Does anyone have a spare good ignition coil for cylinders 3 and 4?
No; but we know a man who has brand new Dynacoils and Taylor leads for that very bike he no longer (never did in the first place) needs. :P
I bet you get them cheap. :blowout:
Dcrosby13
Re: Bad start
Post by Dcrosby13 »
bit too steep to be honest, its a standard bike so probably wouldnt benefit from them either. Just after a standard one :)
willandrip
Re: Bad start
Re: Bad start
I saw you put the bike back up on the bay
Dcrosby13
Re: Bad start
Post by Dcrosby13 »
Yeah I don't need two FZR's I was just being greedy, we have all been there :whistle:
Re: Bad start
Dcrosby13 wrote:Yeah I don't need two FZR's I was just being greedy, we have all been there :whistle:
yeah ... haven't we :o :sshh:
