I've been doing some much needed maintenance and i have found few troubling things about my NC21. First there was a broken bolt on the crankshaft holder, luckily it came out easily. Tightening torque should be 12Nm according the NC21 specs i got, but these bolts were tightened at much higher torque so I am not even surprised one bolt was snapped off. Second issue was the valve clearence - almost none at all. So I recommend to anyone who is buying old vfr to check the valve clearence. Next thing i noticed is that the carbs i replaced were slightly different. I bought them as NC21 carburators but it seems they are NC24 (32mm). After I got the bike running again and synced the carbs together the bike still runs as if they are out of sync (holds 1300 almost as it should but the 1300-5k range is unstable - revs to 5k). I am not sure if its caused by the differente size of carburator intake or something else. I already set the mixture screw to 2 and 1/4 turns out. I haven't checked the float level on new carb yet and i will when i get the chance - i forgot to check it when carbs were out. Do you have any other ideas how to fix this issue or what else could be causing it?
Sorry for any typos - I am not native english speaker.
Thanks,
Lukas
