Nc30 rear pads
Nc30 rear pads
Has anyone any suggestions on removing a very tight rear pad retaining pin? I've had to remove the caliper and the pin end is being soaked in plus gas, as I'm on the verge of rounding the Allen key its that tight. As there is limited clearance to get anything on the pin, I'm lost as to whether anyone has overcome this before, any help most appreciated
Tom
Cardiff.
Tom
Cardiff.
- Bike owned: RVF400 NC35
Re: Nc30 rear pads
can i just clarify you do mean the actual pin, and not the little lug thats screwed in after it?
Re: Nc30 rear pads
You must use a good quality allen key in the pad pin otherwise you will destroy it.
Ive used an impact driver with good effect on sevearl stuck pad pins and pad pin plugs where owners have not cleaned and anti-sieze compunded them in the past.
Fit and quality of part is good, a well fitting proper made part will get it undone no issuse, poor parts will chew it up and it will need drilling out.
Re: Nc30 rear pads
i had to hacksaw into the pin plug slightly just so i could get some grip with a slot screwdriver
