Engine oil
Repsolnc30
Bike owned: Zx636 B1h, vfr400 nc30, rgv250
Engine oil
Post by Repsolnc30 »
Just after some info I know I need 10/40 oil and how much to put in but what's better semi or fully synthetic ??
Repsolnc30
Re: Engine oil
And also what brand to go for please
VFRkieran
Bike owned: NC30, NSR250, CBR600, TS125
Re: Engine oil
Post by VFRkieran »
This has been discussed quite alot lately, some people use fully synth to good results some say the clutch slips while using it, i have good results using motul 5100 semi synth, if i remember right 2.4l is how much you need, probably worth getting yourself a haynes manual.
Morespeedvicar
Re: Engine oil
Post by Morespeedvicar »
Hi, yeah I use fully synth Castrol power one I think its called, my nc30 and fzr4 love the stuff, and wouldn't use anything else in my 400's now. Just don't use car fully synth as you will get clutch slip!!!!! I've tested this on me trail bike and using car full synth oil made its clutch slip but bike oil doesn't.
Ian
code2006
Re: Engine oil
Post by code2006 »
I also use Castro power one in my nc35
Had no problems with it
mo haggs
Bike owned: bikeless
Re: Engine oil
Post by mo haggs »
I use Castrol power 1 racing 10w/30 in my race bike.
GeeTee
Bike owned: NC30 & GSXR750K4
Re: Engine oil
Post by GeeTee »
I'm running Morris super sport 4 10/40 in my NC30 track bike
Consumption was just under 1/2 a litre on my last days thrash around Brands Hatch Indy
http://www.morrislubricants.co.uk/scrip ... roduct=168
Repsolnc30
Re: Engine oil
Thanks for replies thinking of getting castrol power 1 semi synthetic 10/40 is that a decent choice ?
Re: Engine oil
Post by Neosophist »
Stock 10/40 semi-synth of a decent brand should be more than adqueate for normal riding. Whatever is cheaper between fully / semi synth BIKE oil I usually buy.
Fully synth is not required to provide proper lubrication so the main benefit becomes longer changing intervals due to the superoir breakdown qualities of fully synth. If you change fully synth as often as semi-synth then your just throwing money away in my eyes.
Haydn
Re: Engine oil
Post by Haydn »
I use She'll advance ultra 4 fully synth in my track bike. I heard of the clutch slip rumour so I did a bit of research before and the shell stuff meets the JASO standard so it won't cause clutch slip. £32 including filter and wrench from Busters. Free delivery too.
