NC35 emulsion tubes
sniff
watafu
Re: NC35 emulsion tubes
If I remember correctly, 5holes for the rear cylinders and 4 for the front cylinders, if in doubt check out the carb guide on this forum
Your thoughts are correct, the top 2 tubes in the pic are for the rear cylinders.sniff wrote:Mixed up the tubes when cleaning, which set goes to rear bank?
My initial thought is top ones, with the lower hole, to rear cylinders, but....many thanks
That info applies to NC30's only, rvf parts are quite different.watafu wrote:If I remember correctly, 5holes for the rear cylinders and 4 for the front cylinders, if in doubt check out the carb guide on this forum
sniff
many thanks...
