Cbr 600 rr swingarm on cbr 400 nc29
tanuki
Re: Cbr 600 rr swingarm on cbr 400 nc29
Post by tanuki » Fri Jan 31, 2014 12:10 pm
why would you increase the wheelbase of a 29 slowing the steering and taking away the whole point of a 400 its sharp handling?
Just a question not trolling.
ANDYC8888
Post by ANDYC8888 » Fri Jan 31, 2014 3:17 pm
tanuki wrote:why would you increase the wheelbase of a 29 slowing the steering and taking away the whole point of a 400 its sharp handling?
My thoughts too.
ANDYC8888
Post by ANDYC8888 » Fri Jan 31, 2014 4:04 pm
Unfortunately the earlier ones are 610mm long too.
That plan has just been filed under B1N :down:
keithyscbr
Post by keithyscbr » Fri Jan 31, 2014 7:00 pm
Im coming to the same conclusion ha ha another idea binned
PARUS
Post by PARUS » Thu Apr 10, 2014 10:53 pm
1. Red lines show how much need to be cut from each size to fit cbr600 swing arm to NC29 frame.
2. Green is extensions you need to fabricate to fit beating into the holes.
3. I'm recommend make extensions first, weld them and only after than cut from each side.
Here is measurement of NC29 swingarm in NC29 frame.
