Does anyone know where this piece goes??
ryancusick
Post by ryancusick »
Its from around the radiator area... i think. I re-painted it black due to bad rusting.
Spike16
Re: Does anyone know where this piece goes??
Post by Spike16 »
i think its part of the top mount on the lower rad, there are rubber gromits and two of these slid inside each of them, thats just a guess tho
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
it looks like the spacer that fits into the top mount on the lower radiator.
william
royster81
Post by royster81 »
top mount or bottom mount on the top rad where the infil panel bolts in or where the rad mounts to the coil bracket or as said top mount on the bottom rad right hand side where it mounts to the front head
ryancusick
Its the same one that is on the top of the bottom radiator. Could someone take a picture in round the radiator areas?? The Hanynes manual is a bit shitty for putting stuff back together.
Thanks guys
Ma77
Post by Ma77 »
If you are sure it was from the radiator area remove the radiator cap and place it inside. Once the cap is re-installed start the bike and let it idle untill it is warm....it will by then have found where it is meant to be. :shock:
(Don't) ;)
