NC30 rear disc removing question.
Locked
bikemonkey
Re: NC30 rear disc removing question.
Post by bikemonkey »
Shouldn't do. Someone may correct me but I think it needs re-valving to suit the heavier spring to ensure it performs the best, but you could just have it re-sprung.
xivlia
Bike owned: Ducati 749 D
Post by xivlia »
yeah in the tutorial it says "depending on how much you want to spend, you may want to get it re valved" so i assumed it wasnt critical. but il ask the garage and see how much they will charge etc.
bikemonkey
I wouldn't send it to any garage. A specialist is your best bet, get it done right once not once wrong and once to correct the wrong.
xivlia
Post by xivlia »
yeah i smell money... im not prepared to pay 3 figures on shock re-valving. il get it re-sprung, i was watching a video on changing a spring, apparently you only need a c-spanner to get the lock ring off and the rest is easy. but this was for a different shock. il see if its the same concept for the bmw one.
bikemonkey
You'll need a spring compressor too, that I'm sure of.
xivlia
Post by xivlia »
well this is how he does it.. its looks straight forward but like i said its not the same make. i just watched to see how it was done and thought maybe they all have the same concept
http://www.youtube.com/watch?v=cAvCschxqxI
Cammo
Post by Cammo »
The bmw shock has a bottom collar, you need to compress the spring to remove it.
xivlia
Post by xivlia »
ahh i see.... is there any good and easy ways of compressing this?
jetblack
Bike owned: '89 NC30 SEED
Post by jetblack »
errr....spring compressors? :roll:
No doubt another £20 you're too toght to spend to do the jo properly which will enevitably end up with you creating a post called 'I smashed my teeth out- whats the cheapest way to fix this?"
It don't matter if i'm fixin' it or ridin' it.
xivlia wrote:sorry about that whole thing jetblack, i just got confused about the whole thing, and i didnt mean any disrespect to you.
VFRkieran
Bike owned: NC30, NSR250, CBR600, TS125
Post by VFRkieran »
jetblack wrote:errr....spring compressors? :roll:
Haha that made me laugh. Anyway Ersan there isnt a cheap way to take the spring off, using a good set of spring compressors will still be quite a bit of hassle. Most places that overhaul shocks will have a big hydraulic compressor to remove the spring in about 20 seconds but one of those will set you back alot of money. Will be worth asking some local garages if they have one, wouldnt cost you much to swap the springs over too.
Locked
