Can you see what it is yet
Maelstrom
- Bike owned: MC22, 3TJ1
Re: Can you see what it is yet
Memoirs of a motorcycle mechanic.
USE SAFETY GLASSES
To remove lower bearing.
1/ Use a large lever to pry the bearing cage off. All the rollers will fall out as you do this and it is easy.
2/ Use an angle grinder to grind a flat (only ONE) on the bearing ring from the top to almost the bottom. You can't go all the way down or you risk hitting the lower fork crown clamp with the grinder. You should leave the ring about 2 mm thick. That way you have no chance of hitting the stem with the grinder.
3/ Use a cold chisel to crack the inner ring. It is not too difficult as the bearing steel is quit brittle.
4/ Ring can be pulled off easily.
To install new Bearing.
1/ Pack with grease.
2/ Place on stem and square up.
3/ Invert the old ring cracked ring and slide down onto the top of the new bearing. It makes the perfect drift because it is the perfect size.
4/ Use a piece of pipe that fits over the stem and strikes the inverted old inner ring to tap the new bearing into place.
Your done!
USE SAFETY GLASSES
Your done!
Carb seal kits in viton & other parts
https://litetek.co
https://litetek.co
willandrip
Or; as you have already been caught by wife with tank in bath !!!! :
Place Yoke in plastic bag in freezer for 2 hrs and put bearing in a sealed bag in boiling water for half an hour .
remove both and slip bearing by hand over bottom yoke .
Viola.!!!!!!!!!!!
Viola.!!!!!!!!!!!
The way I did it - big screw driver to break the bearing open.
Big screwdriver at 90 dgrees to the steering stem between tripple clamp and bearing cup, tap it in to make an edge.
Drift and hammer to move it.
loose paitience, use the M10 bolt and a flange nut as a drift with a lump hammer.
I've used the freezing bearings / shafts meathod before and usually end up whumpping it anyway
- Hogdigerdy Dog
so there's more than one way to skin a cat
and too be honest i use a variation of all three,
it's the grind bend and remove method, followed by the heat it, freeze it, tap it, then whack it into submission to re-install method
but as long as it's seated square and undamaged, the jobs a goodun and it's time for a cuppa
Couple more parts I'll need are the braket that sits above the pillionseat lock and the undertray (not the mudgaurd) ... if you've got a spare let me know
- Hogdigerdy Dog
afraid not chap
just had a scan through the 3tj section on the bay and nuthin doin
but judging by the amount of early fzr parts advertised as 3tj, you'll probably find the bit's you want in the genesis section
rockTJ
- Bike owned: GSX650F FZR250x2 RSV RG80
I think I may have a spare bracket. I will text you a pic.
Chris
Chris
Yeah - about that .... A while back I found myself on the road to Oxford. it was nice when I set off but I took my scooter jacket in case it got cold. It pissed down. Lucky the jacket's waterproof neoprean and a low lining so it's stretchy and goes over my leathers.Hogdigerdy Dog wrote:afraid not chap
I got there and it was a 3en1.
He was embarrassed and gave some latex mechanics gloves by way of tribute (4 boxes
Got a double flash on the way home
- thunderace
- Bike owned: R6, YZF600R
You just like hitting things don't you Boris?
It's how you hit it though
