WHERES MY SHIM
Re: WHERES MY SHIM
How difficult is it to remove that bolt on the outside of te engine?
- vfrman
- Bike owned: NC30, 1098s
Re: WHERES MY SHIM
Easy once the carbs are off..10mm wrench IIRC.
Re: WHERES MY SHIM
happened to me once, but the engine was on the bench, so I had to turn the engine upside down and 'shake it out'. Luckily, the engine was pretty dry so it didn't stick to anything.
- Smev
- Bike owned: NC30 of course
Re: WHERES MY SHIM
Just done the valve clearances on my NC.
Didn't drop any and did stuff rag into all possible holes that the shims could fall into.
Better be safe than sorry.
Mister Donut Rep NC30
Re: WHERES MY SHIM
I took my cam gears out, was a total waste of time for me.chuchu20 wrote:I'll probably search around my work area again tonight.
If no luck how do I take the gear that drives the cams out? Is it the 4 nuts around it.
If that doesn't work I'll probably take the sump out of the right side engine casing.
As VFRMAN said theres 4 bolts and one in the centre... the rear cylnder one is a bastard to get to without removing the water pipe in the middle (and you would ideally want to replace the rubber gaskets you disturb) much easier to get clutch / sump off.
- vfrman
Re: WHERES MY SHIM
Oh yeah, I totally forgot about that damn pipe being in the way!
Re: WHERES MY SHIM
Hey guys so finished the valve clearance the other day.
Thanks for all your help, i took off the right side engine cover and found the shim down in the sump.
- vfrman
Re: WHERES MY SHIM
WOO HOO!
Lesson learned, huh?
- Bike owned: CB-1, MSX125
Re: WHERES MY SHIM
Dude, your sig is nearly half a page. Do us all a favour and slim it up a bit please? If you must use this space to mock a fellow member, you can always do it without Quote tags and multi linefeeds, but I would argue it's bad form particularly from a mod.vfrman wrote:WOO HOO!
