- vfrman
- Bike owned: NC30, 1098s
So, have you swapped out the cable that goes to the starter? It REALLY sounds like the starter isn't getting enough current to make things happen.
- missis sumner
- Bike owned: NC30 + Teapot
Battery clamps - are they tight?
It does sound electrical to me.
- xivlia
- Bike owned: Ducati 749 D
well. i havent changed the cable that goes to the starter, but i have ran the starter without the starter clutch and it was spining no problem. i had done this with my old starter clutch which was broken. battery clamps are all tight
vic-vtrvfr
Surely even a weak starter will spin when no resistance against the rotation?xivlia wrote:well. i havent changed the cable that goes to the starter, but i have ran the starter without the starter clutch and it was spining no problem. i had done this with my old starter clutch which was broken. battery clamps are all tight
- vfrman
With all the other crap you have swapped out, I would take a serious look at that cable. That vid really sounds like the starter isn't getting the required current. The fact that it is intermittent makes me suspect the wiring even more.
stick the bike in gear, push it forward with the clutch out, put it back in neutral, does it jam?
- mo haggs
- Bike owned: bikeless
I'd put money on it being the battery.
I know you changed the battery not so long ago, but i recon its fucked.
Just because it reads ok on the meter don't mean its up to the job.
Have you took a reading of the battery when you're trying to start the bike?
- mo haggs
Is your handle-bar bent out?
- xivlia
well ive tried both batteries that i have, the old one wasnt even fucked, i just thought it was. i will have a look at that cable again.
magg
- Bike owned: VFR400
16.84 volts at the battery is a problem in itself that needs to be investigated. As others have said , sounds like the battery is in need of charging and the wiring from the battery to the stater motor needs checking, both +ve and -ve paths. Low battery and high lead or starter relay resistance will cause the stater to stall , not jam.
With a charged battery, measure the voltage directly at the starter motor when you press the starter button. Should be the same as the voltage at the battery terminals. If not then you have a dud connection somewhere between the battery and the starter motor.
