Where posts and threads can be moved to future safe keeping.
Locked
xivlia
Bike owned: Ducati 749 D
Post by xivlia »
checked the cdi aswell, no problems there. one thing, does the stator control the sparking on these bikes aswell? maybe ive burnt the stator... didnt check that at all.
porndoguk
Post by porndoguk »
Your doing your trick if asking a question, then asking more questions without checking out the answer of the first question in hand,
Pick ups, go check, they are the sensors that signal to cdi, to then signal to the coils to pulse a spark charge.
Stator goes to the rectifier, turning 50v ac to 12v dc that is all
Kill switch
xivlia
Post by xivlia »
http://www.ebay.co.uk/itm/HONDA-VFR400- ... 1c24b7ae7f
that is the pulse generator coil ... or pickup as youd call it? right.
porndoguk
Post by porndoguk »
CMSMJ1 wrote:Kill switch
Forgot about that,
Thats happened to me before go get ya slippaz and dressing gown on, go check now!
I did at 1am in my boxers when spent hours trying to get her to start when i realised in bed, couldn't sleep without knowing
xivlia
Post by xivlia »
kill switch is on the on position. but i will disconnect that and see if that is the cause......
xivlia
Post by xivlia »
nah kill switch is fine.. the pulse coils are fucked im getting way too high resistance from them
magg
Bike owned: VFR400
Post by magg »
If you disconnect the kill switch you will remove power to the ignition unit. Have you checked for 12 volts on the black/white wires at the ignition coils and the ignition unit?
xivlia
Post by xivlia »
i disconeected the kill switch, but then the ignition wont work, so i reconnected it. but i had checked the ignition coils and CDI and they were all fine. i think my main problem is the pulse coils.
magg
Bike owned: VFR400
Post by magg »
What was the resistance reading? Unusual to have both trigger coils fail at the same time. Do you disturb them while changing the starter clutch?
Locked
