RVF 400 Fan Switch
chuchu20
RVF 400 Fan Switch
Hey guys
Does anyone know how to put a fan switch on an RVF 400? Done it once before on a cbr250, just connect the fan switch to ground. Cant seem to find out how to do it on the RVF. Thanks
phil x
- Bike owned: 2 x 650 Transalp's, '90 nc30
Re: RVF 400 Fan Switch
Yep, the fan is permanently live (off the ignition), use a switch to earth & complete the circuit.
Phil
Phil
arsey30
- Bike owned: ftr223 650 bros
Fit a fully insulated piggy back spade terminal to save cutting into the existing wiring.
chuchu20
Where did you mount the spade connector too? Is it to the bit the hangs off the left of the bottem rad? The fan switch I think it's called?
arsey30
The green wire goes to one side of the new manual switch and the piggy back spade pushed onto the existing rad fan switch.
The original fan switch wire spade [black shrouded] pushes onto the piggy back connector.
The wires are hanging off in the picture to show more clearly their fitting, picture is new spade removed from rad fan switch.
- CRM
chuchu20
All good got it all to work tonight thanks
