Drilling Swingarm for brake line
- Bike owned: Yamaha wr125x and Nc30
Hi guys I was wondering if there was any info on this I've done a search but not found a great deal.
How big are the holes you drill? Where exactly do you drill them? And does this weaken the Swingarm caused anyone any trouble with mot etc
Any help is much appreciated
Re: Drilling Swingarm for brake line
think ricky(porndog) done this mod mate, try giving him a pm. sure he wouldnt mind.
Check out the link below, it'll give you a pretty good idea how to go about it...
viewtopic.php?f=24&t=23940&start=0&hilit=swingarm
and a few more photos from Akhara...
http://www.akhara.com/nc30/nc30rearbrakeline/index.html
Good luck
Good luck
i drilled 2 x 20mm Dia, one in the centre just behind the shock,
the hole you drill near the hub end there is a (20mm ish dia) circular manufacturers mark from the cast mould, you need to drill central to this 10mm towards the front as if you drill directly on it youll screw up and drill into the hub/bearing holder.
Rick
Rick
RoninZX-10R wrote:Check out the link below, it'll give you a pretty good idea how to go about it...
Good luck
saved me having to search
Thanks for the help guys
