Where posts and threads can be moved to future safe keeping.
Locked
iDemonix
Bike owned: '92 NC30
Post by iDemonix »
I'm impressed you've dragged this problem out for so long.
magg
Bike owned: VFR400
Post by magg »
At this point my only suggestion to read the Honda Common Service Manual, I will attempt to upload a copy. In it is an explanation of how the rect/reg works and a test procedure for the battery charging system.
I would be interested to see the doc that describes the functionality of the rect/reg as a linear shunt design. The info available to me indicates that the OEM design is shunt type that shunts off the output of the alternator. The power dissipated in the "shunting SCRs" is what heats up the body of the rect/reg. A FET type rect/reg is also a shunt type but the on resistance of the FET devices is much lower than that of an SCR and therefore the body of a FET rect/reg does not get as hot.
Post by Neosophist »
xivlia wrote:okay.. so i checked the three yellow wires at the reg/rec while its connected and the engine is running...at 2.5k rpm im getting 22-24VAC...i mean the AC volts is going in.. its just not getting regulated by the reg/rec.....what do you guys think? i know magg said <2 VAC would mean a dead reg/rec..but im getting 22-24v at 2.5k rpm..is that too much?
Are you an idiot?
Do the tests I put in my big post above.
Do all of them in that order and post the results and i'll tell you whats wrong.
Your supposed to have 50v at 5000rpm.
magg
Bike owned: VFR400
Post by magg »
xivlia unfortunately you are confusing the situation. Initially you said you measured <2 VAC between the three yellow wires with the rect/reg connected and now you claim to have 22-24VAC. It cannot be both unless there is an intermittent connection in the loom between the alternator and the rect/reg.
magg wrote:xivlia unfortunately you are confusing the situation. Initially you said you measured <2 VAC between the three yellow wires with the rect/reg connected and now you claim to have 22-24VAC. It cannot be both unless there is an intermittent connection in the loom between the alternator and the rect/reg.
He did say he had the meter set to the wrong volts which would cause the incorrect reading.
However, follow all of the tests I specified above at the specified RPM and reply back with those, they are taken more or less directly from the workshop manual.
Follow them and reply with what you have then you'll get an answer to what is wrong.
iDemonix
Post by iDemonix »
Maybe an NC30 isn't for you Xilvia...
Jashdown
Post by Jashdown »
Maybe everyone should stop posting help. He obviously isn't listening and is doing what he likes to sort the problem. He can learn the hard way, if at all.
Matchlessman
Post by Matchlessman »
Are you an idiot?
44 pages sort of answers that doesnt it.
This is certainly a bike to avoid when it comes up on ebay.
xivlia
Bike owned: Ducati 749 D
Post by xivlia »
im not an idiot...im just new to bikes...have limited amounts of electrical knowledge... the owner i bought from said it never had many problems....and to be honest it never had any charging issues...im thinking i fucked up when i started to jump start from my dads car WHILE the car was running.... and i did this several times. this is why im thinking the charging is fucked.. okay just give me some fucking time. stop calling me an idiot. i will figure this out...
xivlia wrote:im not an idiot...im just new to bikes...have limited amounts of electrical knowledge... the owner i bought from said it never had many problems....and to be honest it never had any charging issues...im thinking i fucked up when i started to jump start from my dads car WHILE the car was running.... and i did this several times. this is why im thinking the charging is fucked.. okay just give me some fucking time. stop calling me an idiot. i will figure this out...
All you have to do is do the tests in the step by step guide I posted above, post back with the results and I can tell you what is wrong, it isn't rocket science.
NC30's are KNOWN to have weak charging systems, an old dead battery will easily kill an already dying one off, you may have made it worse by trying to get the bike to charge a dead battery several times but I wouldn't believe any owner who said it's never had charging problems before.
I've jumped bikes from running cars before without problems, it's not wise to let the bike charge up the battery from dead though, especially with an old battery and a weak charging system.
Folllow the steps I posted on page 43 and reply with all the results at the RPM's and settings I specified and go from there
Locked
