Titanium Axles for NC29
selexon
Bike owned: FZR400R 2TK, CBR400RR NC29
Post by selexon »
Hey Chaps,
I' am looking at machining up some new axles for my NC29 racer. And would like to know if anyone else would be interested in this little project.
My plan is to keep the std front axle design (with alloy spacers) but change the rear to a quick change set-up similar to what Ducati run on the late model dual swingarms. ie. Having the axle incorporate a flange or nut so it locks into the adjuster and all you need is one socket/spanner to undo the left nut and then you are able to slide the axle through and out.
Any thoughts?
cbr400rrn
Bike owned: NC29 CBR600F
Re: Titanium Axles for NC29
Post by cbr400rrn »
What price are you looking at?
selexon
Post by selexon »
cbr400rrn wrote:What price are you looking at?
Not to sure yet but have been checking on material length and cost, obviously the more I order the less it cost.
To do 4 frt axles I need 960mm @ $36.00 per 100mm < rough calculation on what prices I have so far.
tanuki
Post by tanuki »
interested in this (and your caliper bracket) just finding it hard to picture what you mean.
Are you doing Ti front axles as well?
Yakama
Post by Yakama »
I would be interested too
selexon
Post by selexon »
tanuki wrote:interested in this (and your caliper bracket) just finding it hard to picture what you mean.
I will try and organise a picture or a photo so you can see what I mean.
Yes I am doing front and rear axles in Ti, I have started on the front as it seems a bit easier to machine first.
tanuki
Post by tanuki »
I've been thinking about it and I understand what you mean, I would be interested but it all comes down to price lol
matt69
Bike owned: NC29, CBR6F2
Post by matt69 »
selexon wrote:Hey Chaps,
Any thoughts?
Yep I'd be interested too. Price might be the deciding factor, but I'm running out of other weight loss options on mine.
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti »
If it helps, the front is probably the same as vfr400, certain vfr750, cbr600, etc. as these wheels are all cross compatible. knowing Honda probably loads of other models too. You turn up the strangest things when you look eg the rear axle in a cb-1 is same part number as cbr600f1, which is same as cbr600f1 swingarm bolt, too!
matt69
Post by matt69 »
Has this gone anywhere?
Matt
