Were would I buy a Bearing kit for the suspension linkage on my 3tj.... One of them looks past its best !
or can you but them from a Bearing specialist ?
Shock Linkage Bearings
- Bike owned: CRM 250 CBR600 YAMAHA FZR 3TJ
- Kayla850
- Bike owned: Sunn Tzar S2
Re: Shock Linkage Bearings
You can either get the bearing code off the bearing and use that, or measure the bearing and give the measurements to a local bearing supplier. Lots of people use these-
http://simplybearings.co.uk
or
http://www.bearingboys.co.uk
or
www.projection-racing.com
www.pjcfasteners.com
try Yamaha ... you might get the linkage as one assembly. I'm not saying you'll get it cheap but it might be cheaper than you think.
I've got an R6 linkage somewhere
- Bike owned: TDM850, FZR400RR and others
You should be able to get the bearings from Fowlers (there number is on the web) that is where i get most of my parts.
The part numbers for the bearings you need are:
93317-21746-00 qty 2
93317-31701-00 qty 2
I got these numbers off the parts fiche that 'cagiva996' pointed me in the right direction for in another thread so you can double check the numbers for yourself and any other bits you might need like the seals.
A bearign specialist will probably be cheaper but you need to push all the bearigns out first to measure them.
Hope you get it sorted soon!!
You don't really need to measure them the bearing code will give you that info.
- Bike owned: fzr 400
i have all the bearing codes for the 1wg written down somewhere not sure if they would be the same bearings though, give me shout if you want them, id buy them direct from a bearing supplier as they are usually cheaper.
Thanks all for all of your advice..... If I have time today I'll tap them out & have a look.
