Billing's Bikes
- BillingCBR
Re: Billing's Bikes
Drunkn Munky wrote:Your be mad to break that rvf engine, it's near on mint and low millage from what I remember.
I'm still undecided, I might just clean it and give it a once over, then see about fitting it. I'm after a set of RVF cams though, I want to fit them to give the bike a bit more poke, along with the NC24 slides (just got to rubber grease them before fitting, bargain at £15) and Ignitech. I'll try and fit that at Ricks, see how it performs on the way home
Cheers bud, I'm going to get loads of pics, and will be taking it very slowly and doing things properly with itYakama wrote:Sounds good will look forward to seeing how you get on.
Can you get programmable CDI's for the NC23?
Dunno if you can, I'll ask Graeme and see what he can hook me up with if there's anything about. I'm hoping that there's something, remove the limp mode when I remove the speedo, and give the best possible ignition map
- BillingCBR
Re: Billing's Bikes
I'll be leaving to collect the Ignitech in about 7 hours
Very excited, I'll probably fit it and the UK speedo when I get home, I'll report back with how much different it feels
- BillingCBR
Re: Billing's Bikes
I decided to sort out my speedo out, a little while ago I bought a set of UK MPH clocks with a really scrappy casing (the usual place)
I have what I suspect is an RC30 casing, so swapped them over, a small change, but they look 10 times better IMO
The reason I suspect the replacement of being an RC30 part is that the 'OIL' and 'TURN' idiot lights are switched, and a little bit of ebay/google research shows this to be the RC setup
- BillingCBR
Re: Billing's Bikes
Ignitech is on, going to go test it out
- mattUKNC
- BillingCBR
Re: Billing's Bikes
2 of the VFR's, the UK clocks and my CBR have Oil above neutral :S it's literally only the new surround that's got Turn above Neutral.
The Ignitech is GOOOOOOOOOOOOOOOOOD!!!! Fitted it and had a quick go, revs and pulls harder, and I don't get quite so many afterfires when I back off the throttle. Big
to Rick O, what a great chap, was great meeting him, and he spent loads of time talking me through things, and generally enlightening me to the world of RC30's :D I'll definately be back again if he'll let me
- ibby4585
- Bike owned: SP's
Re: Billing's Bikes
My seed has the oil and turn the other way around too.
Re: Billing's Bikes
my surround is damaged in the exact same place and the same sort of damage!!! what does this then??
- BillingCBR
Re: Billing's Bikes
Don't know how to explain it then Ibby, maybe it was something that changed between the years or something?
lizard, not sure exactly, but it's the clutch cable adjuster ring catching it that does it I think, probably where people tilt the lever too high so it then catches on right lock
Re: Billing's Bikes
Correct,BillingCBR wrote:Don't know how to explain it then Ibby, maybe it was something that changed between the years or something?
mines surfered from Clucth Adjuster Rash!
dont know how people can ride with it that high anyway?
