Billing's Bikes
- alexwitham
Re: Billing's Bikes
Get the ignitech cdi and programme it with the 'improved standard' map from Rick. That's the best in road form. The full blown HRC map is best for Track/Race use as it has better high RPM torque but lower bottom end.
- micpec
Re: Billing's Bikes
I agree with the mentioned parts..eerhmm...parts wish list on previous page 17
Billing, tbh best put your pennies on the Ignitech. Probably start with the pre-HRC map an go from there. The TSR system is made for race/track use, upper midrange to high range revs, get it set up right and if needed combined with best optimum carbs adjustments and off you go
- BillingCBR
Re: Billing's Bikes
Cheers for the thoughts guys, looks like I'll be hitting his ROness up for ignitechy goodness
Hopefully it'll make a noticable difference, given that my bike isn't that far off standard engine wise
Is it possible to make a map that helps get around noise testing (retarding the ignition or something) as I have a feeling I won't be able to pass noise regs at any track days
- BillingCBR
Re: Billing's Bikes
Got a tip about some cheap Samcos, so saved myself around £10 including buying the clamps. I'm going to use the rest of the money (around £50) to put petrol in the tank
Got the MOT booked for tuesday and got the insurance ready from 5pm on monday night :)
Will definately hit Rick O up at the end of the month if I can afford it (insurance looming @ £220
) for the Ignitech, and will probably leave it at that for now, and save up for a couple of months for the big rads, and possibly RVF cams and RO road needles
- BillingCBR
Re: Billing's Bikes
searching ebay earlier I found a set of carbs listed simply as 'vfr400 carbs' clicked the picture and saw they had curve bottomed slides, so put an offer in, which was accepted
So will nick those, and sell the NC24 carbs on for a bit less, not bad for £20 all in IMO
- BillingCBR
Re: Billing's Bikes
As of 20 minutes ago I'm insured to ride the VFR for the last month of my policy
Can't wait to get on it tomorrow for the MOT
- BillingCBR
Re: Billing's Bikes
Good news! And it's NOT the Dacia Sandero! The VFR now has a green slip saying it's fine for another year
Re: Billing's Bikes
What did they say about the exhausts?? nothing
- uber pikey
- Bike owned: NC30, GS700e GSX750 katana pop
Re: Billing's Bikes
Well done mateBillingCBR wrote:Good news! And it's NOT the Dacia Sandero! The VFR now has a green slip saying it's fine for another year
I saw it so I took it!
- BillingCBR
Re: Billing's Bikes
Got an advisory or 2 (or 8!) all on stupid little things that I knew would get mentioned, 2x low tyre tread, loud exhaust, slightly pitted front discs, low tyre pressures (only noticed when I arrived that they looked a bit squishy) and some other stuff I can't rememeber atm.Drunkn Munky wrote:What did they say about the exhausts?? nothing
The tester likes the exhausts, says that they're just about the right volume to be nice sounding, but not so loud they would upset someone.
Cheers Curt, did feel rather good seeing the green slip
