NC30 - Hole in Cylinder 4?
porndoguk
Post by porndoguk »
ive just clocked that there is a small 6mm ish hole in cylinder 4 just bellow the engine mount bolts.
is this right?
or should there be a screw or something in there. ive just had a look in a hurry as i discovered it momenets before i had to go out at 6.30pm so not investigated if there are any threads etc in there.
arsey30
Bike owned: ftr223 650 bros
Re: NC30 - Hole in Cylinder 4?
Post by arsey30 »
Seems to be long tunnel in the head, made during casting/manufacture.
Dave.
uber pikey
Bike owned: NC30, GS700e GSX750 katana pop
Post by uber pikey »
porndoguk wrote:ive just clocked that there is a small 6mm ish hole in cylinder 4 just bellow the engine mount bolts.
is this right?
I would be more worried about the engine mount bolt missing mate :o
I saw it so I took it!
There is no bolt missing..that lower bolt is used by RVFs and not VFRs.
ref that hole..hmm..looks familiar. is it not the spark plug draining hole?
porndoguk
Post by porndoguk »
that bracket and hole is where my m10 threaded rod passes through for my crash bungs.
and that said bracket has been fabricated buy the previous owner where the m6 exhaust stud snapped a cracking invention, which will come off one i get a new exhaust and drill and re tap a m6 hole on the near future.
come to think about it when i got the torch in there to see what was lurking i could see some stamped writing so could well be the spark drain hole didnt know they had them but would make sence with them being so deep.
arsey30
Post by arsey30 »
I put the air line to it, it is a plug drain hole.
Dave.
porndoguk
Post by porndoguk »
thanks for that guys, is there the same said holes on the other 3 cylinders then? i hadnt noticed it before you see.
Post by Neosophist »
Yes its spark plug drain hole.
there should be one on the other side too
