Removing fork bottoms, NC35
Post by Drunkn Munky » Sun Dec 12, 2010 9:52 pm
Can someone explain how you remove the fork bottoms from the leg, after they've been stripped of course ;)
BillingCBR
Re: Removing fork bottoms, NC35
Post by BillingCBR » Sun Dec 12, 2010 10:01 pm
the chrome part and the part where the caliper bolts to? As far as I'm aware they're screwed on, if not actually part of them :)
Cru Jones
Bike owned: NC35
Post by Cru Jones » Sun Dec 12, 2010 11:49 pm
I'm not familiar with taking the bottoms off the NC35, but with GSXRs they're screwed and epoxied (or some other adhesive) on. So, I'd assume the NC35s are similar. Why do you wan to take them off?
ludacris
Bike owned: NC35
Post by ludacris » Mon Dec 13, 2010 9:29 am
i'm assuming Tony is wanting to do some sandblasting and powdercoating?
Post by Drunkn Munky » Mon Dec 13, 2010 10:14 am
ludacris wrote:i'm assuming Tony is wanting to do some sandblasting and powdercoating?
Spot on, go to the head of the class :grin: + i want the tubes coated
Post by CMSMJ1 » Mon Dec 13, 2010 11:47 am
pretty sure they are screwed on. Bet they'll have a grub screw too?? More spinach required?
ludacris
Bike owned: NC35
Post by ludacris » Mon Dec 13, 2010 12:01 pm
Drunkn Munky wrote: Spot on, go to the head of the class :grin: + i want the tubes coated
YES! what colour are you thinking? i've actually pondered this too...i have settled on sand, primer, paint when i get around to doing the calipers...which will have to wait til i get new lines, discs and pads :grin: just seems like it would be easier waiting to do it all in one go
red fork bottoms + gold calipers :drool:
Post by Drunkn Munky » Mon Dec 13, 2010 12:14 pm
CMSMJ1 wrote:pretty sure they are screwed on. Bet they'll have a grub screw too?? More spinach required?
Thats what i thought, more spinach on the way :grin:
Gold nitraid for the tubes and satin black for the fork bottoms, dunno about the calipers, i may try something other than gold for a change, maybe satin black again with polished nissin letters.
L.Svedberg
Post by L.Svedberg » Mon Dec 13, 2010 1:16 pm
Yes I know how to remove them:
Make sure you have a vice with jaws for the correct diameter of the stanchions (chrome leg), then use soft metal (alu or copper sheet metal) to prevent the vice from destroying the surface. Clamp the leg tight, then use a heater gun to thoroughly heat the bottom part where it's screwed on. Make sure you've reached at least 120 degrees C, and then use the front axle7spindle from the bike to unscrew.
Reason for heating is the bottoms are Loctited in place, and will NOT come off cold. Do not try, or you will destroy the threads in the alu parts.
Good luck!
/Lasse
Post by Drunkn Munky » Mon Dec 13, 2010 1:31 pm
Cheers lasse, bang on the money there.
When you say correct jaws for the vice do you mean there are specific jaws available to suit different sized tubes?
