Requesting all Hugger info
- craigs23
- Bike owned: Quite a few
Re: Requesting all Hugger info
I think that's an NWS hugger, that used to come with a bracket made.
I had one on my RVF, so please excuse the old photo. I've highlighted the bracket needed. It's a T-shape that bolts onto the swingarm and then onto the shock linkage (from what I remember).
The magical racing one i had mounted to the right hand side of the suspension linkage, IIRC it used some kind of special fixing, not something i would have thought you could buy off the shelf.
EDIT: Im pretty sure mine was craigs one one from the reply above
hunter
guess who thats the one i have,
Drunkn Munky, the special fixing is a deep nut that replaces the linkage nut and has a blank end with 6mm thread
tapped in it for mounting.
CammyGTIR
Thats mine too!
Is this a part youy sell Gav? Or does anyone want to sell one?
Cam
Cam
- Gavin jap4
we do a mounting kit but not sure if it is the same as that one
hunter
Ok guys i think i'v cracked the upload problem i'v had.
anyway here goes.
anyway here goes.
Dynamohum
best pic i can get off mine in situ its not as deep at swinging arm as the others pictured.the white bit on the bottom right is the predrilled hole. apologies for the picture using an old digicamera gavin do you think the fitting kit you have would be suitable for this ?
CammyGTIR
Gavin, does your mounting kit fit like that to the hugger? If so, its the one I'm after.
- Gavin jap4
CammyGTIR wrote:Gavin, does your mounting kit fit like that to the hugger? If so, its the one I'm after.
from recolection it looks very much the same as that one
Dynamohum
gavin could you pm me a fitting kit price please ?
