Critical wheelbase
PARUS
Critical wheelbase
Hi guys,
Have anybody play with different wheelbase. The standard wheelbase is 1,365mm. As I remember somebody on the old forum told me that he run 1320 - 1330 mm and it was ok. Will be appreciate any info.
justmartyn
- Bike owned: Only 2 left.....
Re: Critical wheelbase
I pulled the wheel right forward and stuck a 15:45 sprocket combo on for what was essentially a go-kart track at home and found it turned a wee bit quicker, flicked from left to right very nicely, but never compared it with where I would normally have the wheel (mid markers). Dont ask me about top end stability as I dont think I was ever above 4th gear.
PARUS
Thank you for response. Did you change chain length or run with stock 102 links ?justmartyn wrote:I pulled the wheel right forward and stuck a 15:45 sprocket combo on for what was essentially a go-kart track at home and found it turned a wee bit quicker, flicked from left to right very nicely, but never compared it with where I would normally have the wheel (mid markers). Dont ask me about top end stability as I dont think I was ever above 4th gear.
justmartyn
From memory I stuck with the standard length, thats why we ran 15:45 and not a 14:42. However I've never actually sat down and counted my links when changing chains, I just offer it up and knock the pin out where it fits.
