The weight list.
- superlite
- Bike owned: TLS, LB80 x 2
Re: The weight list.
L.Svedberg wrote:HRC Honda RS250 Works rear axle, including both nuts and wheel spacer 945 g. Std axle 1925 g.
'Take it to the Back'
- Tim400GB
modified Fireblade ohlins maybe?rallykay wrote:Does anyone know from what bike the 2000 gr ohlin came from?
Will try and get my one weighed soon
I think the weight will be relative to the model of shock. I would presume that each model gets lighter than the last.Timon wrote:modified Fireblade ohlins maybe?rallykay wrote:Does anyone know from what bike the 2000 gr ohlin came from?
The ohlins TTX series will probably be the lightest available to the masses.
Maelstrom
- Bike owned: MC22, 3TJ1
How about the frame and the swingarm? I know that it is assumed that one would never want to change these but I beg to differ.
amorti
- Bike owned: CB-1, MSX125
The swingarms are heavy, not to mention the weight of the axles and eccentric hub.maelstrom wrote:How about the frame and the swingarm? I know that it is assumed that one would never want to change these but I beg to differ.
There was one fella on here used an aprilia swingarm, I think? Took lots of work of course. Looked aces.
- micpec
I did some measurements today on a couple of parts and here & there on some miscellanous items, not sure if these measurements are handy but just check what you may like to know and/or add to the existing weight list
(Later more to come...)
* NC35 standard front riders seat pad : 585 grams
* NC35 (Spiegler) gear link rod : 38 grams
* NC35 standard gear link rod : 67 grams
* NC35 titanium gear link rod : 33 grams
* NC35 carb rubbers in total all 4 pcs new : 91 grams
* Exhaust gasket 18391-MN5-650 new : 20 grams each
* NC35 rear pillion seat pad + cable iron strap : 842 grams
* NC35 silhouette single seat pad : 353 grams
* NC30/35 Speedo to gear box assy (44800-MR7-000) used : 92 grams
* NC35 standard RHS air duct excluded the rubber strip : 86 grams
* NC35 standard LHS air duct included the rubber strip : 100 grams
* NC35 Airblade DB screen new + screen rubber : 422 grams
* Pro Bolt NC30/NC35 Titanium pinch bolt : 41 grams
* GSXR1000 rotor flywheel K7-K8 + bolt : 650 grams
* Pro Bolt Titanium front disc bolt : 4 grams each
* Cheap chinese made NC35 indicator housing + clear lens + bulb + 5 cm wires : 75 grams
* NC35 standard rear brake light switch cable assy : 25 grams
* HRC overflow bottle new (19602-NF4-810) : 40 grams
* Front wheel bearing new (FAG 2RSR) : 65 grams
* Thicker walled (RO) vacuum tube : 36 grams
* NC35 (RO) carb screw kit allen type : 82 grams
* Quick action throttle + bolts : 134 grams
* NC35 standard indicator housing + cable assy : 115 grams
* NC35 mirror assy (RHs or LHS) + small spacer + 2 nuts : 259 grams each
* Oil filter (Meiwa) new (52 5110 / H1013 / H1014) : 210 grams
* NC35 rear top mount suspension u-fork (50233-MZ7-000) new : 141 grams
* Braking Wavy front disc used : 1210 grams each
* TSR brake fluid reservoir band new : 24 grams
* NGK-R standard EH9EH spark plug used : 19 grams
* NGK-R Iridium ER9EHIX spark plug new : 18 grams
* NC30 carbon tank pad (brand unknown / used ) : 27 grams
* NC35 Endurance front headlight cover POSH : 128 grams
* NC35 kevlar air ducts RHS or LHS : 130 grams each
* NC35 carbs idle screw set (16029-MR8-900) new : 44 grams
- micpec
I have just weighed a couple of more small bits and pieces...(again I am 100% not sure if these are measured before, so please add to the weight list if necessary
* NC35 standard rear wheel nut: 85 grams
* Titanium custom made rear wheel nut: 45 grams
* Titanium Pro-Bolt rear wheel spacer: 117 grams
* NC35 standard rear wheel spacer: 77 grams
3" HRC Magtek inc bearings and spacer: 3.5 kg
You got one eh? Win!
Aye Winning!CMSMJ1 wrote:You got one eh? Win!
