NC23 fork change
NC23 fork change
what are my optiong for updating the Forks on my NC23?
Re: NC23 fork change
I no that NC29 forks fit
They may sit a little higher in your yoke but there better hechnology than the old nc 23 ones
the best upgrade you could do is later model NC29 forks that are fully adjustable fitted with NC30 lowers meaning you can use the NC30 4 pot calipers.
early cbr600..you get preload,comp and rebound...they sit alot higher tho...have seen the mod on nc29
properly set up nc23 forks will work as good...if not better than nc29 forks
i still race my 23 with 23 forks...air caps n all still fitted...and it handles magic
stimpy
stimpy
Stimpy would you be be able to write a guide on setting up nc23 forks properly?
obviously making what is already on the bike perform perfectly would be the best option money wise
sure others would appreciate the info to :D
Id be interested in a setup guide also.
im planning on building up my other nc23 to race in another class
i can do a report and post pics once im underway
the biggest help i got when i started the first build was from graeme...he has all the bits when it comes to setting them up,
the technology in the suspension is simple,and straight forward with the 23,they only really req some decent springs in the front,good oil and a better rear shock.
stay tuned
stimpy
stay tuned
stimpy
