The weight list.
RickOliver
Re: The weight list.
Post by RickOliver »
Thanks, Mark, I`ve been meaning to add -
Rick Oliver upper radiator - 900g
(well it`s lighter than HRC...!)
Simon_Ed
Post by Simon_Ed »
i know the rear 3 spoke dymag is approx 1kilo lighter than standard 17''
rallykay
Post by rallykay »
Updated with this new info!
Thanks guys.
Kay
fourfingers
Bike owned: NC30RK,NC35RR
Post by fourfingers »
Here´s a little contribution, rally.
Rear shock springs (to compare relative weigh, spring rate and leght should be taken into account)
showa nc35 1108 gr (Free length 188mm, 140Nw mm??)
öhlins 1106gr (Free length 147mm, 150Nwmm)
Wilbers 1010gr (Free length 150mm, 120Nwmm)
RCS 650gr (Free length 147mm, 120Nwmm) Titanium coil, öhlins fit
Titanium will be around 40% lighter than steel, same as with nuts and bolts.
I am currently running the RCS on a öhlins,15mm preload, but would be better off with a 130Nwmm, even though I´m a light jockey (60kg)
lange
Post by lange »
The Tyga Twin Stack alu muflers are 900g each
Power is nothing without control!
rallykay
Post by rallykay »
Updated with the two above and my new puchase.
A 370 gr durbahn 2,3A battery!
And it has a CCA of 300A so it will be more than enough for a carbed bike.
Keep them coming!
RonniB
Post by RonniB »
Hi
late type NC30 forks, only the fork legs (no yokes, spindel, mudguard or brakecalipers), but ready to go (meaning springs and oil) 7.1 kilo
Ronni
arsey30
Bike owned: ftr223 650 bros
Post by arsey30 »
When you have done all you can to lighten the bike, then get your weight down as much as possible.
Finally, Casio do a titanium watch and Specsavers do titanium framed spectacles for those that wear them.
Dave.
rallykay
Post by rallykay »
arsey.
Since last winter i am down 20 pounds, the Specsaver titanium i allready got, but the watch is a good tip.
Thanks! :D
Spike16
Post by Spike16 »
err or u could just take the watch off..... ;)
for the true weight contious the way forward is riding stark bollock naked with knee sliders duck taped on, o and mabe a neck tube...wouldnt want to be getting cold would you :D
