30 engine into 35
- mo haggs
- Bike owned: bikeless
Re: 30 engine into 35
no worries - thanx for the heads up.fourfingers wrote:About spacing the sprocket, I had to do it the other way round, 35 engine in 30 frame, so had to space out rear sprocket carrier.Please check for exact offset as 5mm quoted from memory... and did this 3 years ago.
think im just goin to put in a standard unit for now and do the genny mod a bit down the lineDrunkn Munky wrote:Mo, try and pickup a G-force adaptor kit for the gixxer kit, Im pretty sure i got mine all in for under £300
Well i can confirm that the chain run is visually out so yes we do need a spacer, now we just need to find out the exact measurement. surely someones done this before?????
- mo haggs
you're further along than i am so im no help at the min
ive got a 5mm spacer on the way, i'll let you know if it works
- mo haggs
Forgot to update this, i ended up with the RO chain spacer kit (only the front sprocket part) which spaces the front sprocket out 5mm. Visually it looks spot on and so far ive done atleast 100 miles on it with no problems.
- fourfingers
- Bike owned: NC30RK,NC35RR
Guess my memory is not that bad after all... Nice to hear everything is going fine
- mo haggs
nice one, im waiting for a few parts to arrive so i can go a little further
