stalling and non starting GK76a
- Reactions:
hi i have a 1991 GSXR400 and have very limited knowledge as im a new rider. i have trouble starting it even when bumped. when it (eventually!) starts, it idles and sounds reasonably healthy but as soon as i go to ride it stalls and fails to start again. i had it serviced and carbs cleaned in Nov but has been only started a few times since and petrol may be stale? will redex help? can anyone help with this?? any advise will be gratefully received!! many thanks
Andy
Andy
- Awynn
- Reactions:
- Bike owned: GK73a, CB250, NS125R-K, CLR125
Re: stalling and non starting GK76a
Did you replace the dredded O-rings in the carbs? If not then there is your likely problem.
- Reactions:
ill have to contact my mechanic to find that out, if not, is that an easy thing to check and replace myself??
- Awynn
- Reactions:
As long as you are able to pull the carb insides apart and put it all back together again (with new O-rings of course) then it is a fairly easy job if you take your time. To be honest the hardest part is usually getting at and removing/re-installing the carbs from the bike.
- Reactions:
excellent im going to give that a go. ive found a page of instructions for removing carbs. the set of o-rings ive found do not include 'bowl gaskets', is it vital i replace these too?
- Variablevalves suck
- Reactions:
Hi J,
If the o'rings are from fleebay they are from me, regards bowl gaskets rf600 are the same but about £6 each so i only change em if they leak.
Chris.
Chris.
- Reactions:
cheers for the o rings mate and the advice from you both but ive made a decision to sale the bike as it is. havent got the time to have it fixed and i will potentially be missing many riding weekends trying to get my head round it. new bike on the way. look out for my gixxer on ebay very soon.
- Awynn
- Reactions:
- Reactions:
Joner: u say the RF 600 Float boal gaskets are the same, is the Jet holder crush gasket also the same ??
- Reactions:
Hi Andre,
This is a link to the RF600 kit so you can see if the gasket is the same. Think it is just the bowl and the o'rings altho i sell the o'rings for £11.
http://cgi.ebay.co.uk/SUZUKI-RF600-RF-6 ... otohosting" onclick="window.open(this.href);return false;
Chris.
Chris.
