R1 fork conversion GSXR (gk76a)
- Variablevalves suck
- Reactions:
Re: R1 fork conversion GSXR (gk76a)
VERY NICE work Andy
If you fit the R6 fotks can you do a dog a faver and post me the distance between each fork leg center as they are mounted in the yoke. I got thundercat in my B4 and using the stock Suzi yoke the forks are held slightly closer together than they should be and the calipers run very close to the spoke of the wheel, so if the R6 measures up alittle wider i may get some.
Many thanks Chris.
Many thanks Chris.
- Reactions:
- Bike owned: R1x2 98/2k/Gp125/73a/76a/76a
Hey Chris,Variablevalves suck wrote:VERY NICE work Andy
Many thanks Chris.
As near as i can be the measurement your after is 160mm.That`s between the the fork end`s(spindle) and the same measurement between the fork`s right up at the bottom of the bottom yoke,hope that`s where you mean mate.....
Andy
- Reactions:
Cheers for that
- Reactions:
Nice work., I'm thinking of doing the same with the big bang front end , but I'm having billet yokes made., as its going to be a one off build with a nc24 swingarm and a t500 stroker engine
- Reactions:
Nice job I'm doing the same to my build
Gsxr400r frame
T500 engine
Nc24.swingarm
Vfr750.rear.wheel
Gsxr400r frame
T500 engine
Nc24.swingarm
Vfr750.rear.wheel
