GK71F Having some electrical (?) issues
Posted: Wed Feb 07, 2024 3:54 pm
Hi all,
I have an imported GSX R400 that I picked up a little under a year ago. Recently as I was going to ride it home from the gym it started having issues a minute or so after I cranked it up. It was bogging down, would only run with full choke, was making no power and the tach stopped working. I had to push it home and the next day I fired it up and it worked fine (tach worked, sounded fine, held idle) until it got up to operating temp then it had the same issues as before. I thought It was the ignition coils that were failing so I replaced those and no luck, it still has the same issues.
Before I throw more money at it does anyone have any idea what might be causing this? Im assuming its the an issue in the igniter unit (part #32900-32b10) but if anyone knows how to test it or could point me in the actual right direction Id really appreciate it.
