Gk73 sp engine identification?
topfridgeman
Reactions:
Bike owned: 1 or 2
Post by topfridgeman » Tue Jan 01, 2019 9:59 pm
Hello.
Does anyone know the best way to identify an sp engine on a gk73 gsxr? My friend has about 6 engines, one of which he thinks is an sp.
Thanks.
Col.
moforockband
Reactions:
Bike owned: GK73a SP CRM250 mk3
Re: Gk73 sp engine identification?
Post by moforockband » Mon Jan 07, 2019 9:35 pm
They are visually identical. The only way you can check is to pop off the rocker cover and check the cams and rockers/valve springs to positively identify.
But you need to know what you are looking for.
Variablevalves suck
Reactions:
Post by Variablevalves suck » Sun Jan 13, 2019 9:52 pm
Also have shorter inlet but you would only be able to see this if the manifold is still attached.
SP only has a short rubber inlet and the non SP has an ally spacer between the rubberone and the head so lengthening the inlet, has a different air box to allow for this.
If you go back to the previous post it lists engine numbers for the SP.
