hi guys, recently my friend's gk76a neutral light is not lighted up when its on neutral gear. any idea why? what could be wrong? bulb? sensor?
Re: no neutral light
Posted: Tue Aug 23, 2011 10:19 pm
by Variablevalves suck
Test the bulb first, if no good check the neutral wire to loom connection under the seat and finally test sensor.
You should get a circuit through the neutral wire to ground when in neutral.
