Zxr problems
Danclark
Reactions:
Zxr problems
Post by Danclark » Wed Sep 24, 2014 5:34 pm
Hi I'm new. New zxr400h. It's been sat there over a week so I go to start it and it didn't wanna go. No problem, I'll bump it.....stupidly as I move it I've twisted the throttle too far and now it doesn't spring in either direction. Please tell me this is an easy fix
mrrowley87
Reactions:
Re: Zxr problems
Post by mrrowley87 » Wed Sep 24, 2014 6:50 pm
Hey the throttle off and see if it's disconnected at the throttle end. If not then have a look at the carbs under the tank. If not there then check the carbs operate and return by manually moving the lug the throttle connects to. If that springs back then the cable has snapped and you need a new one
Danclark
Reactions:
Re: Zxr problems
Post by Danclark » Wed Sep 24, 2014 7:00 pm
Cheers dude I'll take a look tomorrow. Guess you just undo a couple of screws the throttle end with the starter block?
mrrowley87
Reactions:
Re: Zxr problems
Post by mrrowley87 » Wed Sep 24, 2014 7:02 pm
Yes. It wraps around a white plastic cam inside. The carbs end should be just as simple.
Danclark
Reactions:
Re: Zxr problems
Post by Danclark » Wed Sep 24, 2014 7:34 pm
Don't suppose anyone has a new throttle tube?
Return to “ZXR - General”
