3TJ6/7 throttle cables
				Maelstrom
- Bike owned: MC22, 3TJ1
Hi All,
I picked up a set of FCR's from a 3TJ6, so now I need throttle cables.
Anyway if I could get an old set I will just send them to Venhill and get some replicas made or do the same if I can get the dimensions from someone. If you can help or know someone that can it would be much appreciated.
Blair
Blair
https://litetek.co
						https://litetek.co
Re: 3TJ6/7 throttle cables
I haven't seen those cables - I guess they're different
I have a set of flatslides that came with cables they're on my imgur page https://imgur.com/gallery/ysqfXhV if they look the same I can measure the cables for you.
				Maelstrom
Thanks but I cannot see the cables on that page.
They both have adjusters on the ends and one also has an adjuster closer to the throttle.
You can also see that difference in the parts book.
https://litetek.co
						https://litetek.co
				Maelstrom
Someone has modified your bracket, perhaps to use the Mikuni cables.
https://litetek.co
						https://litetek.co
So are you trying to use the standard cables ???
				Maelstrom
The standard 3TJ6 cables. If I can get the detail or find an old set that would be good. If not I will just make up to fir from Venhill parts.
https://litetek.co
						https://litetek.co
I only have a pair of standard cables for a 3tj
				Maelstrom
I bought a set of used cables from a YZF750-SP. Will be simple enough to do any length adjustments to suit the smaller bodies if needed.
https://litetek.co
						https://litetek.co
