R6tacho conversion
- Reactions:
R6tacho conversion
Hi evil it’s the original thunder cat tci. and yes the tps is connected I don’t know what the previous owner has or has not done to it I am flying blind as there are not many thunder cats here in Australia some one suggested that it may need a diode between the tachometer wire from the tci igniter unit and the tachometer it’s self I’ll give it a try it can’t hurt
It’s about the only thing I haven’t done I know the r6 tachometer and speedo works as I have a 3en1with a 3he 600 motor fitted but the loom on the thunder at is a fair bit diffent
- Reactions:
Re: R6tacho conversion
Hmmm ... see how it goes. I'm doing a similar conversion but used the 4JH cdi so I didnt need the TPS .
- Reactions:
- Bike owned: MC22, 3TJ1
To fit an R6 to my 400 I needed a divide-by-two gizmo see here https://litetek.co/R4/Guide_R4_InstrumentCluster.html
Carb seal kits in viton & other parts
https://litetek.co
https://litetek.co
