Will fzr600 carbs work on my 88 400?
Sanlot17
Post by Sanlot17 » Thu Aug 21, 2014 1:57 am
Didn't know if they would. Mine is all messed up! Cracks and such. Thx.
Re: Will fzr600 carbs work on my 88 400?
Post by Evilchicken0 » Thu Aug 21, 2014 1:19 pm
Yes, that is I think so.
A usa bike is a bit like a 1WG genesis but different. The carbs are similar to the 600 3HE but they'll need setting up to your bike. It might be that you can get a set of 600 carbs and use them for parts, or you could check out the jet sizes and if they're different transfer them into the 600 carbs.
I'd recommend you get the bike set up on a dyno after, unless you know your way around carbs, although it's expensive it takes a lot of the heartache out of it
