FZR (3TJ) front master cylinder repair kit
sportspromatt
Post by sportspromatt » Tue Aug 12, 2014 11:11 am
Are these kits still available,
part number is 3TJ - W0041 - 50 (or) 4DX - W0041 - 50
any parts supplier worth trying, any contact would be appreciated.
Fowlers are coming in at £35.83 (that's a lot)
Are these interchangeable with other models, ie XV1000 is part no. 4KO W0041 - 50, would a fzr600 be used.
Read a few posts, is a foxeye the same, (What year)?
Re: FZR (3TJ) front master cylinder repair kit
Post by Evilchicken0 » Tue Aug 12, 2014 1:53 pm
I think it's probably a generic rebuild kit for the size of piston. The part number was superseded by 4SVW004100
If you buy a non yam kit it will be about £20-25 so you'd save a tenner. Try and find a yam dealer local to you and save the postage .... that might help a bit.
How's things anyway, haven't seen you on here for a while ?
sportspromatt
Post by sportspromatt » Tue Aug 12, 2014 7:37 pm
Thanks Evil, going ok, except for sponge front brakes :down:
I seen the standard size on here on another post ? so will look for it. its standard 3tj, an SP should be the same.
Most kits online are free postage any way.
Will look further into this when I get a minute, and will post to maybe help others in the future.
Post by Evilchicken0 » Tue Aug 12, 2014 9:20 pm
You could just put another master on from an R6 maybe
rockTJ
Bike owned: GSX650F FZR250x2 RSV RG80
Post by rockTJ » Mon Aug 25, 2014 1:40 am
Using a 5MT '01 R6 master cylinder with a genuine FZR400RR lever - on my FZR250RR. You gotta love Yammies. :P
