iv been lurking in the background or a while now but have recently brought myself a FZR400R 1WG project bike, after owning a VFR400 NC30 i jumped at the chance to have another TROUSER FIREWORK
now my poor 1wg has seen better days the wiring has been chopped and sliced and she’s been down the road more than once
but the reason im here asking for help is she just wont start, iv downloaded the manual ( although its is for US spec bikes unsure exactly what model ) and im working through the ignition trouble shooting section but im having a couple of issues.
so lets start with the basic problem - ign = on and i get my green neutral light no other lights, i press start and NOTHING except the oil light comes on??
iv done some testing main switch and kill switch are ok .
the battery is ok .
the starter solenoid is ok .
the starter is ok .
side stand switch is dead but i have linked this out .
my fuel pump was showing a closed circuit across the terminals with no resistance - this has been replaced but i wouldn’t of thought this to be the cause, just another problem lol.
now i have read up that the relays on these can be a pain unfortunately with the wiring loom being tempered with ( cant even find the main fuse!!) and the manual being for US bikes and i not sure specifically for the 1wg im having trouble identifying which relay is which and what one is most likely to be my problem.
im currently unable to find the clutch cut off relay, starting circuit cut off relay, diode block, digital ignitor unit and fuel pump relay :S
any help advice or even a nudge in the right direction would be great
Thanks in advance Ollie
