I know i also need the rubber boots that sit inside the airbox for the CV carbs but apart from these the throttle and choke cables is there anything else i need to fit CV carbs on a FCR kitted SP?
If all you need are the rubber boots, I should have those in the garage!Drunkn Munky wrote:I know i also need the rubber boots that sit inside the airbox for the CV carbs but apart from these the throttle and choke cables is there anything else i need to fit CV carbs on a FCR kitted SP?
