Changing screen on a 4TJ
VForcer
Bike owned: NC30, CBR6, Blade(2), FZR400RR
Post by VForcer » Mon Mar 07, 2011 12:07 pm
Can this be done without taking the front fairing off?
Going to put new screen and bolt kit on it but the bolts behind the clocks look like a bastard to get to while in situ??
Ta,
Rob
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Re: Changing screen on a 4TJ
Post by Taggyd » Mon Mar 07, 2011 12:16 pm
it is possible, if you can get the old one out, long nose pliers and someone with small hands help! then use captive rubber nuts on the new one you dont need anything underneath to hold a nut.
Post by Evilchicken0 » Mon Mar 07, 2011 12:53 pm
Use a long ring spanner or tape one to another to make an extension.
when you put the new nuts in use a round piece of paper under the ring of the spnner then stick it there with masking tape on the side of the ring. Drop the nut in and when it's tight you can just take the spanner away.
I had to do this when I put in engine mounts on a Mini once.
To be honest it's not that difficult to take the top fairing off.
VForcer
Post by VForcer » Mon Mar 07, 2011 1:38 pm
Nice one chaps ;) Thanks for the replies...
